PETG 3D Printing Filament: Materials, Properties, and Uses
Written byMegan Conniff
19 min read
Published September 19, 2022Updated August 19, 2026
PETG 3D printing filament is a glycol-modified version of polyethylene terephthalate (PET), known for its strength, flexibility, and moderate chemical resistance. PETG offers good durability and moderate-to-high impact resistance among 3D printing filaments. The filament is used in various industries for applications (protective enclosures, mechanical components, prototypes, and outdoor parts) that need to withstand mild environmental conditions (exposure to moisture, but not extended UV exposure). Its ability to maintain structural integrity under mechanical stress and its ease of use make it an essential material in 3D printing. PETG filament is favored in high-volume 3D printing environments for its combination of strength, ductility, and printability, positioning it as a go-to choice for practical applications. The widespread use of PETG filament highlights its growing importance in hobbyist and industrial 3D printing sectors in functional part production.
What is PETG Filament?
PETG Filament is a thermoplastic 3D printing material defined as a Glycol-modified polyethylene terephthalate, which is not a copolyester but a modified homopolymer and recognized under the names PETG and PET-g filament. PETG Filament combines the chemical backbone of PET with glycol modification that reduces crystallinity, stabilizes melt behavior, and improves layer bonding, which supports adoption across consumer and industrial additive manufacturing workflows. A common functional printing material is polyethylene terephthalate glycol-modified (PETG) filament because it offers balanced toughness, moderate chemical resistance, and good dimensional stability without the high brittleness typical of highly crystalline polymers. PETG Filament demonstrates reliable printability through consistent extrusion flow and strong interlayer adhesion, with lower warping than Acrylonitrile Butadiene Styrene (ABS) on common fused deposition modeling platforms. PETG Filament provides mechanical strength through high impact resistance, moderate tensile strength, and ductile failure behavior that suits enclosures, fixtures, and mechanical housings, with outdoor use dependent on UV exposure and environmental conditions. The Filament maintains structural performance under moderate repeated stress while supporting smooth surface finish and limited post-processing methods such as vapor smoothing, but supports sanding and machining, reinforcing material selection for functional end-use parts where thermal and fatigue limits remain controlled.
"PETG stands out as a practical middle-ground material in 3D printing, balancing strength, ductility, and print reliability without the processing demands of higher-temperature polymers. Glycol modification reduces crystallinity, which supports strong layer adhesion, low warping, and consistent extrusion across both consumer and industrial workflows. Its mechanical toughness, moisture resistance, and moderate heat tolerance make it well suited for functional parts such as enclosures, fixtures, and outdoor components with limited UV exposure. As a result, PETG has become a dependable workhorse filament, reflecting the growing demand for materials that perform reliably under real-world mechanical and environmental conditions."
What Type of Polymer is PETG?
PETG is a glycol-modified polyethylene terephthalate classified as an amorphous thermoplastic polyester. PETG is synthesized by modifying the polymerization of PET with glycol (typically CHDM) to prevent crystallinity and enhance processing that disrupts crystallinity, reduces internal stress during cooling, and stabilize melt behavior during fused deposition modeling. Transparency, moderate chemical resistance, impact toughness, and ductility make PETG suitable for functional 3D printed parts that are required to withstand harsh environments and maintain dimensional consistency. PETG offers advantages for 3D printing through strong layer adhesion, relatively low shrinkage compared to ABS, and improved resistance to brittle fracture under mechanical load. PETG differs from Polylactic Acid (PLA) through higher impact resistance and improved thermal stability, while PLA emphasizes stiffness, dimensional accuracy, and ease of extrusion. ABS emphasizes higher heat resistance and rigidity, while PETG presents lower warping behavior and lower odor and particulate emissions during printing. PETG occupies a middle ground among common 3D printing polymers by balancing strength, toughness, and print reliability for applications including mechanical housings, protective enclosures, and outdoor components as a Polymer Material.
What is PETG Filament Made Of?
PETG is made by modifying polyethylene terephthalate (PET) with glycol, forming an amorphous thermoplastic polyester. with reduced crystallinity and improved melt stability. PETG Filament consists of long polymer chains built from terephthalic acid, ethylene glycol, and glycol modifiers that interrupt regular molecular packing and limit crystalline growth during cooling. The filament exhibits a predominantly amorphous polymer structure with limited crystallinity that supports consistent extrusion, strong interlayer bonding, and good dimensional stability during fused deposition modeling. PETG Filament demonstrates balanced 3D printing behavior through controlled melt flow, reduced internal stress during cooling, and improved resistance to brittle fracture under mechanical loading. Polylactic Acid relies on aliphatic polyester chains derived from lactic acid and emphasizes stiffness, surface quality, and low processing temperature. Acrylonitrile Butadiene Styrene (ABS) relies on a rubber-toughened petroleum-based polymer structure that emphasizes heat resistance and rigidity while introducing higher shrinkage and warping tendencies. PETG Filament occupies a middle position between Polylactic Acid and Acrylonitrile Butadiene Styrene, combining toughness, moderate chemical resistance, and reliable print performance for functional parts under UV and temperature exposure.
Is PETG Considered a Plastic?
Yes, PETG is considered a thermoplastic polymer used in manufacturing and additive manufacturing. PETG belongs to the copolyester family and forms through copolymerization of polyethylene terephthalate with glycol modifiers, producing a melt-processable material with reduced crystallinity and stable melt behavior. PETG appears in 3D printing, packaging, and industrial applications because the material offers toughness, moderate chemical resistance, and dimensional stability under mechanical stress and controlled environmental exposure as a plastic material.
What are the Properties of PETG Filament?
The properties of PETG Filament are listed below.
  • Melting Point: PETG Filament does not present a sharp melting point because glycol modification reduces crystallinity, producing a broad softening range that supports smooth extrusion during fused deposition modeling.
  • Glass Transition Temperature: PETG Filament reaches glass transition in the range of 75 to 85 degrees Celsius, defining the temperature range where the material transitions from rigid behavior to rubber-like deformation under load.
  • Temperature Resistance: PETG Filament maintains structural integrity at moderate service temperatures and resists deformation better than low-temperature polymers such as PLA under sustained heat exposure.
  • Flexibility: PETG Filament demonstrates moderate flexibility through ductile deformation rather than brittle fracture, supporting impact resistance and load-bearing performance in functional parts.
  • UV Resistance: PETG Filament offers moderate resistance to ultraviolet exposure, supporting limited outdoor use with gradual degradation unless UV stabilizers or protective coatings are applied.
  • Hygroscopicity: PETG Filament absorbs moisture from the environment at a moderate rate, requiring dry storage conditions to preserve surface finish and extrusion consistency during printing.
  • Heat Resistance: PETG Filament resists thermal softening better than PLA under continuous mechanical stress while remaining below the heat tolerance of high-temperature engineering plastics.
What is the density of PETG?
The density of PETG is approximately 1.27 grams per cubic centimeter or 1270 kilograms per cubic meter. PETG density reflects a relatively compact polymer structure that contributes to part weight and dimensional stability, while resistance to deformation depends primarily on mechanical properties rather than density alone. PETG density influences printed component mass, producing parts heavier than PLA, while improved impact resistance and structural reliability result from polymer toughness and ductile deformation in functional applications.
What is the glass transition temperature of PETG?
The glass transition temperature of PETG is 80 degrees Celsius. PETG reaches glass transition near that temperature range where the polymer transitions from rigid solid behavior to rubber-like deformation, representing an approximate upper limit for dimensional stability under sustained load. PETG glass transition temperature supports strong layer adhesion by allowing interlayer diffusion when deposited above glass transition, while shape retention during cooling results from gradual solidification as the material cools below that threshold.
What is the heat resistance of PETG?
The heat resistance of PETG under continuous mechanical load ranges up to 60 to 70 degrees Celsius before noticeable softening and creep occur, depending on part geometry and load conditions. PETG maintains limited structural stability below its glass transition temperature, supporting functional parts exposed to moderate heat, while deformation increases rapidly as temperatures approach glass transition. PETG shows higher heat resistance than Polylactic Acid at 55 to 60 degrees Celsius, while remaining below Acrylonitrile Butadiene Styrene, which tolerates continuous service temperatures near 80 to 85 degrees Celsius.
Does PETG Shrink?
Yes, PETG shrinks during cooling, although shrinkage remains low compared to thermoplastics used in fused deposition modeling. PETG shrinkage results from thermal contraction as extruded material transitions from melt to solid, introducing limited dimensional change and reduced warping risk. PETG maintains print stability through controlled cooling, consistent bed adhesion, moderate build plate temperatures, and reduced internal stress resulting from glycol modification.
Is PETG Waterproof?
Yes, PETG is considered waterproof in practical use because the polymer exhibits very low water absorption and does not dissolve or chemically degrade when exposed to moisture. PETG forms polymer chains with low permeability that limit water penetration, while strong interlayer adhesion during printing supports waterproof parts when extrusion parameters achieve adequate layer fusion. PETG suits applications involving liquid contact and limited outdoor exposure, while prolonged immersion or insufficient layer bonding introduces seepage risk through interlayer gaps rather than through the polymer material itself.
Is PETG Hygroscopic?
Yes, PETG is hygroscopic and absorbs moisture from the surrounding environment over time. PETG moisture absorption occurs at a lower rate than nylon and also lower than Polylactic Acid (PLA), explaining sensitivity to ambient humidity during storage. PETG moisture content affects print quality through surface roughness, stringing, inconsistent extrusion, and reduced layer adhesion, supporting dry storage and pre-drying practices to preserve material performance.
What is the difference between PET vs PETG?
The difference between PET and PETG lies in polymer structure, processability, and application suitability. PET is a semi‑crystalline or amorphous, but industrial PET used in bottles and packaging is often semi‑crystalline for strength and clarity. Polyethylene terephthalate polymer is used in injection molding, blow molding, and thermoforming, while PETG is a glycol-modified polyethylene terephthalate copolyester with reduced crystallinity. PETG incorporates glycol units through copolymerization with polyethylene terephthalate, disrupting molecular packing, lowering internal stress, and improving melt stability. PET exhibits higher stiffness, higher chemical resistance, and greater thermal resistance in finished products, while PET processing requires controlled industrial conditions due to crystallization behavior and dimensional shrinkage during cooling. PETG supports stable extrusion, strong layer adhesion, and low warping behavior, explaining widespread use in fused deposition modeling and functional 3D printing. PET appears frequently in bottles, food packaging, and industrial films, while PETG appears in 3D printed enclosures, protective components, medical housings, and transparent parts where impact resistance and dimensional consistency are required.
Which filament is better between ABS vs PETG?
PETG is generally better for casual and desktop 3D printing due to easier processing and lower shrinkage; ABS may outperform in heat resistance and stiffness where those are required. PETG provides strong impact resistance and ductile behavior while maintaining lower warping risk and reduced internal stress during cooling compared to ABS. It prints at moderate nozzle temperatures and adheres well to build surfaces without requiring fully enclosed chambers, supporting consistent print quality and improved dimensional stability under typical desktop printing conditions. ABS offers higher heat resistance and rigidity than PETG, which suits applications exposed to elevated temperatures. ABS printing involves higher nozzle and bed temperatures, greater shrinkage, and increased warping risk, complicating print reliability and dimensional control. PETG is tough and ductile, but not flexible in the way TPU or flexible filaments are, while ABS suits structural components that require higher heat resistance and rigid performance in ABS vs. PETG comparisons.
What is the comparison of PETG filament properties?
The comparison of PETG filament properties is shown in the table below.
How does PETG Compare to PLA and ABS?
PETG offers balanced performance between PLA and ABS in mechanical strength and ease of printing, but not in flexibility , it's rigid, not flexible like TPU. PETG offers better impact resistance and ductility than PLA, making it more suitable for functional parts that require toughness. PETG has lower shrinkage and warping than ABS under typical print conditions. PETG offers balanced performance compared to PLA 3D Printing Filament and ABS, with better impact resistance, lower shrinkage, and ease of printing. It provides strength and flexibility, though heat resistance is lower than ABS.
What applications is PETG better suited than PLA or ABS?
PETG is better suited for applications requiring durability, more ductile and impact resistant than PLA, but it is still rigid compared to flexible materials such as TPU or nylon, and moderate chemical resistance compared to PLA, while ABS offers higher heat resistance. PETG excels in producing functional parts that must withstand mechanical stress, exposure to moisture, and mild chemicals, making it ideal for protective enclosures, mechanical parts, and outdoor components where UV exposure is limited. Glycolide-modified polyethylene terephthalate filament is used to print functional parts in 3D printing because of its strength, flexibility, and moderate chemical resistance. PETG offers better toughness, heat resistance, and environmental durability, though its UV resistance is limited without stabilizers, unlike PLA 3D printing filament, which is easy to print but has low heat resistance. ABS 3D printing filament provides strength but is prone to warping and emitting fumes during printing, which can complicate the process, requiring higher nozzle and bed temperatures and more controlled printing environments. PETG provides an effective solution for applications requiring mechanical integrity, flexibility, and moderate chemical resistance in PETG vs PLA comparisons, where printability and performance under stress are important.
Is PETG Flexible comparable to ABS?
Yes, PETG is more flexible than ABS. PETG demonstrates higher impact resistance and greater ductility than ABS, making it more resilient to cracking or breaking under stress. PETG maintains better flexibility and resilience in applications subject to bending or mechanical stress, though its heat resistance is lower than ABS, while ABS is more rigid and offers higher heat resistance. PETG's flexibility makes it ideal for applications requiring strength and stress resistance (enclosures and components), compared to ABS 3D printing filament, which excels in high-temperature applications.
How to Print PETG Successfully?
To print PETG successfully, follow the five steps. First, set the bed temperature between 70 and 80°C and the nozzle temperature between 230 and 250°C for optimal extrusion, with variations depending on specific printer and material conditions. Second, use a moderate fan speed of 30-50% to cool the print and reduce warping, adjusting based on layer height and part geometry. Third, ensure first-layer adhesion by using a heated bed and applying a thin layer of adhesive or ensuring a clean, level print surface, adjusting as necessary for the printer's calibration. Fourth, adjust retraction settings to 1–2 mm for direct drive, or 4–7 mm for Bowden extruders, fine-tuning as needed based on filament diameter and extrusion settings. Lastly, maintain a print speed of 40-60 mm/s for consistent results, adjusting as needed based on print complexity and layer height. Each step ensures strong adhesion, minimal stringing, and a smooth PETG print.
What are the Tips for Printing with PETG?
The tips for printing with PETG are listed below.
  • Clean the bed: Ensure the print bed is free from dust and contaminants to improve adhesion and prevent warping.
  • Apply adhesive: Use a thin layer of glue stick to increase the first layer adhesion and prevent shifting during printing, adjusting based on the specific build surface.
  • Adjust retraction settings: Set retraction to 1–2 mm (direct drive) or 4–7 mm (Bowden), with retraction speed of 25–45 mm/s
  • Print first layers slowly: Slow down the print speed for the first few layers (20-30 mm/s) to ensure strong adhesion and prevent lifting, particularly on larger prints.
  • Manage cooling: Use a moderate fan speed (30-50%) to cool the part evenly, reducing warping and ensuring good layer bonding, though fan speed may need adjustment based on part size and layer height.
The best practices help achieve smooth prints with PETG by focusing on bed preparation, print settings, and temperature management. Following the tips ensures reliable adhesion, minimized warping, and optimal print quality.
What are the Best Print Settings for PETG?
The Best Print Settings for PETG are listed below.
  • Nozzle Temperature: 230-250°C. A higher nozzle temperature helps ensure consistent extrusion and good layer bonding, reducing the risk of under-extrusion, particularly with PETG's higher viscosity.
  • Bed Temperature: 70-80°C. A heated bed helps prevent warping by improving adhesion during printing for the first few layers and reducing internal stress as the material cools.
  • Print Speed: 40-60 mm/s. Printing at moderate speeds helps improve layer bonding and consistency, reducing the risk of defects like stringing or poor layer adhesion.
  • Fan Usage: 30-50%. Use moderate cooling (30-50%) to reduce warping and ensure a smooth surface finish, avoiding over-cooling, which causes poor layer adhesion and print quality issues.
  • Layer Adhesion Strategies: Ensure the print bed is clean, apply a thin layer of adhesive like glue stick and print slowly for the first few layers to ensure strong adhesion and prevent lifting.
What is the ideal nozzle temperature for PETG?
The ideal nozzle temperature for PETG is between 230°C and 250°C. The temperature range ensures consistent extrusion and strong layer bonding, reducing issues such as under-extrusion or inconsistent filament flow. PETG flows smoothly without causing excessive stringing, which can occur if the temperature is too high. The temperature promotes good adhesion between layers, improving print quality and reducing the possibility of warping. Low temperatures can result in poor extrusion and weak layer bonding, while high temperatures can result in over-extrusion, excessive stringing, and poor surface finish.
Can PETG be Printed Without a Heated Bed?
Yes, PETG can be printed without a heated bed, but it is not recommended for most prints. A heated bed (70–80°C) improves first-layer adhesion and reduces warping for larger or complex parts. Printing without a heated bed is possible for small prints if strong adhesives (glue stick, hairspray, or PEI sheets) are used, but it may lead to adhesion issues or deformations. The alternative methods do not match the consistency and reliability of a properly heated bed, while alternative methods can help.
Does PETG Need an Enclosure?
No, PETG does not require an enclosure, but using one improves print quality by maintaining a more stable temperature. Using an enclosure helps maintain a stable temperature around the print, reducing the risk of warping and improving layer bonding for larger parts or during long prints. An enclosure provides additional temperature stability in environments with fluctuating ambient temperatures, while PETG has less warping risk compared to ABS. Printing PETG may be successful in the absence of an enclosure, but temperature fluctuations lead to minor defects (warping or inconsistent layer adhesion) in environments with large temperature changes. Increasing bed temperature and using moderate cooling settings help mitigate the issues for printers without an enclosure.
What are the Common Problems when Printing PETG?
Common problems when printing PETG are listed below.
  • Stringing: Stringing occurs when fine threads of filament form between parts. Troubleshoot by adjusting retraction settings (increase retraction distance and speed) and ensure the nozzle temperature is optimal for the filament, avoiding excessive heat that can contribute to stringing.
  • Warping: PETG has less warping compared to ABS, but it occurs on large prints. Increase the bed temperature, use an adhesive or a heated bed, and ensure the print surface is clean, level, and calibrated.
  • Adhesion Issues: Poor adhesion to the bed leads to failed prints. Use a heated bed (70-80°C), apply a thin layer of adhesive like a glue stick, and ensure the print bed is clean and level for optimal adhesion.
  • Under-extrusion: Under-extrusion occurs when the printer is not extruding enough material, leading to gaps in layers. Troubleshoot by checking the extruder for clogs, increasing the nozzle temperature, or adjusting the extrusion multiplier, ensuring consistent filament flow and material supply.
  • Layer Separation: Layer separation happens when layers do not bond properly due to low nozzle temperature or poor bed adhesion. Ensure the temperature is within the recommended range (230-250°C), and manage cooling to avoid rapid temperature fluctuations that hinder layer bonding.
What is PETG Filament used for?
PETG filament is used in 3D printing for functional parts that require durability, flexibility, and moderate chemical resistance in less harsh environments. The PETG filament is employed to create mechanical components, enclosures, and outdoor parts due to its high impact resistance and ability to withstand moderate environmental conditions. The filament is chosen for producing items (protective covers, gears, brackets, and prototypes) that must endure mechanical stress or exposure to mild chemicals. PETG can be used for medical and food contact items if certified, but most 3D printing PETG spools are not FDA- or medically certified. PETG's ease of printing, combined with its ability to maintain structural integrity under load, makes it a versatile material for a wide range of applications requiring strength and flexibility.
Why is PETG used in 3D Printing?
PETG is used in 3D printing because it offers strong impact resistance, flexibility, and chemical resistance, making it ideal for prototypes, functional parts, and industrial components. PETG provides better durability than PLA, and its printability, compared to ABS, reduces warping and temperature sensitivity, though it has limitations in UV resistance. It is easier to print PETG parts and offers reliable performance in 3D printing for non-food applications, as it withstands mechanical loads and mild chemical exposure.
Is PETG Toxic to Print?
No, PETG is not toxic to print under normal conditions. PETG produces fewer fumes compared to other filaments like ABS, though it releases some volatile organic compounds (VOCs) when heated, which must be monitored in poorly ventilated areas. Safety precautions include printing in well-ventilated areas or using an enclosure with proper ventilation to ensure fumes do not accumulate. 3D printing with PETG is considered safer than printing with other filaments, but it must be handled with safety, including keeping the printing area ventilated and wearing protective gear if needed. PETG is recyclable in theory, but is not widely accepted by municipal recycling programs, unlike being plant-based like Polylactic Acid (PLA).
Is PETG Biodegradable or Recyclable?
PETG is recyclable but not biodegradable. PETG is a glycol-modified polyethylene terephthalate polymer that is recyclable, but it does not degrade naturally like biodegradable materials like PLA. PETG can be recycled, but it is not always accepted in standard PET recycling streams due to differences in chemical properties. Its environmental impact remains higher compared to biodegradable alternatives (PLA) in terms of long-term persistence in landfills. PETG persists in landfills if not properly disposed of or recycled as a plastic, contributing to long-term environmental concerns. Proper recycling practices and reduced environmental exposure to PETG help mitigate its long-term environmental effects.
