Resources3D Printing DesignPETG vs. PLA: Strength and Printing Comparison
 12 min read
Published July 27, 2022
Updated February 17, 2026
Stack of colorful 3D printer filaments. Image Credit: Shutterstock.com/cigdem
PETG and PLA represent two of the most widely used thermoplastics in fused deposition modeling due to their accessibility, versatility, and compatibility with standard 3D printers. PLA is derived from renewable resources that offer higher biodegradability and lower thermal resistance. PETG is synthesized from petroleum-based compounds and provides greater durability and chemical resilience. PETG exhibits superior impact resistance and toughness, making it suitable for mechanical parts, while PLA maintains higher rigidity and tensile strength, typically between 50 and 70 MPa, with low elongation before break. Ductility differs between the two; PETG undergoes plastic deformation and bends under stress without fracturing, while PLA tends to snap when subjected to similar forces. Heat resistance favors PETG, which retains structural integrity at temperatures up to 70–75 °C, while PLA begins to deform near 50–55 °C.
What are the Differences Between PETG and PLA?
The differences between PETG and PLA are shown in the table below.
CategoryPLA (Polylactic Acid)PETG (Polyethylene Terephthalate Glycol)
Category
Material Type
Bio-based thermoplastic derived from renewable sources (corn starch or sugarcane).
Petroleum-based thermoplastic modified for improved ductility and chemical resistance.
Category
Ease of Printing
Suitable for entry-level printing with minimal warping and broad temperature tolerance.
Requires controlled settings due to stringing and adhesion sensitivity.
Category
Printing Temperature
190–220 °C range supports low-energy extrusion in comparing PETG vs PLA temperature
220–250 °C range demands higher thermal input and precise control.
Category
Bed Temperature
The 20–60 °C range allows optional heated bed use.
The 70–80 °C range requires a heated bed for optimal adhesion.
Category
Strength
Tensile strength ranges from 50 to 70 MPa, rigid but prone to fracture.
PETG tensile strength ranges from 45 to 55 MPa with superior impact resistance.
Category
Flexibility
Low ductility, breaks under stress without deformation.
High ductility, bends before failure under mechanical load.
Category
Heat Resistance
Softens at 50–60 °C, unsuitable for elevated temperature use in comparing PLA vs PETG heat resistance
Maintains shape up to 65–75 °C, better thermal stability in warm environments.
Category
Durability
Susceptible to UV degradation and moisture over time.
Resistant to moisture, chemicals, and UV exposure, suitable for longer-term use.
Category
Layer Adhesion
Forms strong interlayer bonds under standard conditions, comparison of PETG vs PLA filament.
Exhibits excellent bonding with minimal delamination risk.
Category
Print Surface Finish
Produces smooth, semi-gloss surfaces with minimal post-processing.
Results in high-gloss surfaces; the high refractive index can make layer transitions more noticeable.
Category
Warping
Low warping tendency, prints remain dimensionally stable.
Moderate warping risk requires bed adhesion strategies.
Category
Stringing
Minimal stringing under standard retraction settings.
Prone to stringing, demands optimized retraction and cooling.
Category
Outdoor Use
Degrades under prolonged sunlight and moisture exposure.
Suitable for outdoor applications due to chemical and UV resistance.
Category
Applications
Ideal for visual models, educational parts, and low-stress components.
Preferred for mechanical parts, enclosures, and functional prototypes.
Category
Part Accuracy
Maintains dimensional accuracy with low shrinkage.
High dimensional accuracy; thermal expansion is slightly higher than PLA but lower than ABS.
Category
Speed
Supports high-speed printing with consistent results.
Requires slower speeds to maintain quality and reduce defects.
Category
Cost
Lower production cost due to simpler formulation.
Comparable material cost; both are widely available as affordable standard filaments.
Category
Toxicity
Emits low fumes, considered safe for indoor use.
Emits mild fumes, ventilation is recommended during printing.
Advantage - Superior performance
Limitation - Requires consideration
Neutral - Standard characteristic
Winner - Best in category
How much more Flexible is PETG than PLA?
PETG is functionally more flexible than PLA because of its higher ductility, which allows it to bend under stress whereas PLA remains rigid. PLA breaks or snaps when subjected to bending forces. PETG deforms and bends before reaching a point of failure. The material properties make PETG suitable for components requiring minor elastic deformation. The elongation at break for PETG remains higher than standard PLA.
Is PETG more flexible than PLA?
Yes, PETG exhibits greater practical flexibility than PLA. This is due to its superior ductility, which allows it to maintain its integrity through bending and impact. PLA tends to be brittle and shatters under stress. PETG maintains its integrity through bending and impact.
What is the Melting Point of PETG compared to PLA?
The melting point of PETG ranges between 230°C and 250°C compared to PLA, which melts at around 180°C to 220°C. Higher temperatures remain necessary for PETG to transition into a flowable state. PLA requires lower energy input for extrusion due to its chemical composition. Proper cooling becomes critical for PLA to prevent sagging. Thermal properties dictate the hardware requirements for each material. Printers must achieve a consistent PETG melting temperature. Accurate control is vital for managing the PETG melting point.
Which Filament has better Heat Resistance, PLA or PETG?
PETG has better heat resistance compared to PLA. PLA begins to soften and deform at temperatures as low as 50°C to 60°C. PETG maintains structural integrity up to 80°C. Automotive interiors or outdoor environments cause PLA parts to fail. Choosing the right material depends on the operating temperature of the final application. Users compare PETG filament vs PLA for functional parts. Environmental conditions influence the choice between PLA vs. PETG filament.
Is PETG stronger than PLA?
No, PLA is not stronger than PETG. Parts printed in PLA resist stretching more effectively than parts printed in PETG. The PETG offers better impact strength and durability despite its lower tensile rating. PLA parts fail abruptly through cracking. PETG parts tend to bend or deform before breaking.
What are the Advantages of PETG Compared to PLA?
The advantages of PETG compared to PLA are listed below.
  • Very Flexible: The material withstands significant bending without snapping. Pliability allows for the creation of snap-fit joints and living hinges.
  • Fairly Chemically Stable or Chemical Resistance: PETG resists degradation from various acids, alkalis, and salts. It serves well in environments exposed to cleaning agents or industrial chemicals.
  • High-Impact Strength (Less Likely to Fracture): Parts absorb energy during collisions without shattering. The characteristics increase the longevity of protective housings and guards.
  • Abrasion-Resistant and Tough: The surface resists wear from friction and mechanical contact. Constant use results in minimal material loss over time.
  • Higher Thermal Stability or Heat Resistance: Components retain their shape in temperatures up to 70°C to 75°C. Stability makes it useful for electronic enclosures that generate heat.
  • Better UV and Weather Resistance: Outdoor exposure does not cause the material to become brittle or discolored quickly. Sunlight has a minimal effect on the structural bonds of the polymer.
  • Water or Moisture Resistance: The plastic behaves as an effective barrier against liquid penetration. It remains stable when submerged or used in humid conditions.
  • Better Layer Adhesion: Molten layers bond together strongly to create a near-isotropic part. Strong bonding reduces the risk of delamination under vertical stress.
  • Glossy Surface Finish: Finished parts exhibit a natural shine that improves aesthetic appeal. Smooth finishes reduce the need for extensive post-processing or painting.
  • Recyclability: The material is technically recyclable but requires dedicated processing streams to avoid contaminating standard PET recycling.
  • Functional Prototype Viability: Real-world testing becomes possible due to the material durability and thermal properties. It bridges the gap between conceptual models and end-use products for Polyethylene Terephthalate Glycol.
What are the Disadvantages of PETG Compared to PLA?
The disadvantages of PETG compared to PLA are listed below.
  • Stringing and Oozing: High print temperatures cause material to leak from the nozzle during travel moves. Fine wisps of plastic require manual removal after the print completes.
  • Hygroscopic Nature: The filament absorbs moisture from the air rapidly. A saturated filament leads to bubbles, popping sounds, and poor surface quality.
  • Difficulty with Supports: Strong layer adhesion makes support structures hard to detach. Removal leaves scarring on the surface of the part.
  • Bed Adhesion Issues: The material bonds too strongly to glass or PEI surfaces. Parts risk pulling up chunks of the build plate if a release agent is not used.
  • Prone to Scratching: The high-gloss surface finish shows marks from handling and abrasive wear easily compared to the more matte-finish options of PLA.
  • Slow Print Speeds: Achieving high quality requires reducing the movement speed of the extruder. Excessive speeds lead to poor bonding and surface defects.
What are the Advantages of PLA Compared to PETG?
The advantages of PLA compared to PETG are listed below.
  • High Tensile Strength and Stiffness: The material offers excellent ultimate tensile strength for rigid applications. Parts remain stiff and do not deform easily under static loads.
  • Flexibility and Toughness: Certain blends incorporate additives to improve impact resistance. Variations provide a balance between rigidity and resilience.
  • Heat-treated (annealed): PLA variants can withstand temperatures exceeding 80°C, surpassing standard PETG. Annealing processes reorganize the molecular structure to improve thermal limits.
  • Chemical and Water Resistance: Standard PLA resists many organic solvents and oils. It maintains its shape in dry indoor environments for years.
  • Good Layer Adhesion and Minimal Warping: Low thermal expansion ensures parts stay flat on the build plate. The material bonds well at relatively low temperatures.
  • Versatile Printing Options: Printers without heated beds or enclosures handle the material successfully. A wide range of colors and aesthetic blends is readily available.
  • Safe for Food and Medical Applications: Raw PLA resin is often biocompatible; however, 3D-printed parts require post-processing to meet safety standards for food contact or medical use.
  • Longer-Term Durability: Parts kept in controlled indoor environments show minimal degradation over time. The material stays structurally sound if protected from high heat.
  • Good for Mechanical Parts: High dimensional accuracy allows for tight tolerances in gear systems. Rigid walls provide the necessary support for internal mechanisms.
  • Compatibility with PLA Prints: Multi-material systems use different PLA types to create complex geometries. Soluble supports bond effectively to the base material of Polylactic Acid during the process.
What are the Disadvantages of PLA Compared to PETG?
The disadvantages of PLA compared to PETG are listed below.
  • Low Heat Resistance: Softening occurs at temperatures around 50°C. Parts left in a hot car warp or melt.
  • Brittleness: Impact or sudden stress causes the material to shatter easily. It is unsuitable for parts experiencing heavy vibration or shocks.
  • Biodegradability Concerns: Exposure to high moisture and microbes leads to material breakdown over long periods. It is not a permanent solution for outdoor use.
  • Difficult Post-Processing: The low glass transition temperature causes the material to soften and gum up abrasives during high-speed sanding or polishing. Achieving a high-gloss finish requires specialized chemicals or techniques.
  • Nozzle Clogging: Heat creep in the extruder causes the filament to swell and block the path. The issue is common during long prints in warm environments.
Download Our FREE FDM Design Guide
What are the Similarities Between PETG and PLA?
The similarities between PETG and PLA are listed below.
  • Thermoplastic Nature: PETG and PLA are both classified as thermoplastics, meaning they soften when heated and solidify upon cooling. This property allows for thermal processing, though repeated recycling cycles can lead to polymer chain scissoring.
  • 3D Printing Compatibility: PETG and PLA are widely used in additive manufacturing due to their ease of extrusion and reliable print quality. Their compatibility with standard printing equipment makes them accessible for a broad range of applications.
  • Cost-Effectiveness: PETG and PLA are relatively inexpensive compared to many engineering-grade polymers. Their affordability contributes to their popularity in prototyping and production.
  • Color and Transparency Options: PETG and PLA can be produced in multiple colors and transparent grades. The versatility supports aesthetic and functional requirements in printed parts.
  • Environmental Considerations: PLA is derived from renewable resources and is industrially compostable, while PETG is a petroleum-based plastic that is technically recyclable, making PLA and PETG 3D printing service suitable for sustainable manufacturing approaches when using closed-loop recycling.
PLA is a bioplastic made from a variety of plant-based materials originally developed as a biodegradable plastic for single use and other applications. Desirable 3D printing attributes are rigidity, low cost, and speed of printing. PETG is a polyester, with glycol added to stabilize it and lower the melting temperature.
Christian Tsu-Raun
Team Lead, Manual Quoting
What are the Best Alternative Materials to PETG and PLA for 3D Printing?
The best alternative materials to PETG and PLA for 3D printing are listed below.
  1. TPU: This elastomeric thermoplastic provides high flexibility, elastic recovery, and vibration damping, with various grades offering flexibility comparable to commercial rubber materials. Users evaluate PLA vs. PETG vs. TPU when selecting materials for gaskets.
  2. ABS: ABS offers higher heat resistance and better post-processing (acetone vapor smoothing) than PLA and PETG, making it a staple for functional and industrial prototypes.. Comparative studies of ABS vs. PLA vs. PETG highlight its superior durability in harsh conditions.
  3. Tough PLA: Specialized additives increase impact resistance while maintaining ease of use. Professionals choose tough PLA vs. PETG for high-strength prototypes without stringing issues.
  4. PCTG: In the comparison of PCTG vs. PETG, the former offers higher optical clarity, better chemical resistance, and significantly higher impact strength than its chemical cousin. The choice depends on the need for superior toughness.
When is Warping most Likely to Occur in PLA and PETG Prints?
Warping occurs most likely when the plastic cools unevenly and pulls away from the build plate. Large flat surfaces are particularly susceptible to the phenomenon. PETG requires a heated bed to improve first-layer adhesion and reduce edge lift, while successful PLA prints remain possible on unheated beds with appropriate surface preparation and adhesion methods. High ambient drafts cause the corners of a print to lift. PETG requires a heated bed to prevent the base from detaching during the cooling phase. PLA exhibits a lower warping tendency than other thermoplastics. Early activation of part cooling fans on the first layer reduces bed adhesion and increases the risk of edge lift or layer separation, which is a leading cause of PETG 3D Print Warping failure.
What are the Benefits of Choosing PLA for 3D Printing?
The benefits of choosing PLA for 3D printing are listed below.
  • Ease of Use: PLA prints at low extrusion temperatures and shows stable flow behavior, which simplifies setup compared to higher temperature thermoplastics, though proper calibration remains necessary for consistent results.
  • Aesthetic Variety: PLA is available in a wide range of colors and specialty formulations, including wood-filled and silk-finish variants, which expand visual and surface finish options.
  • Dimensional Accuracy: PLA exhibits low thermal shrinkage compared to ABS and PETG, supporting superior dimensional stability for precise mechanical fitments.
  • Environmentally Friendly: PLA is derived from renewable plant-based feedstocks and has a lower cradle-to-gate carbon footprint than many petroleum-based plastics; however, its industrial compostability depends on the specific processing conditions of PLA 3D Printing.
A part printed with Xometry's red PLA.
Is PETG suitable for outdoor 3D printing compared to PLA?
Yes, PETG is more suitable for outdoor 3D printing than PLA due to its higher heat deflection temperature and better moisture resistance. PLA exhibits limited UV resistance and softens near its glass transition temperature, which leads to deformation in direct sunlight rather than true UV-driven degradation alone. PETG shows improved resistance to moisture, UV exposure, and moderate outdoor conditions, while long-term exposure leads to material aging and property loss. PETG tolerates wider temperature fluctuations than PLA due to a higher glass transition temperature, though extreme heat still causes softening and deformation.
Is PETG more suitable for high-strength applications compared to PLA?
Yes, PETG is more suitable for functional high-strength applications than PLA due to its superior impact resistance and toughness, even though PLA exhibits higher ultimate tensile strength. PLA exhibits higher stiffness and modulus than PETG, while brittle fracture occurs under impact or high strain rates rather than in all sudden load scenarios. PETG provides improved durability and impact tolerance for functional mechanical assemblies where flexibility and toughness outweigh the need for high stiffness.
The selection between PLA and PETG is often reduced to a simple strength comparison, yet engineers must distinguish between tensile strength (where PLA leads) and impact toughness (where PETG excels). Furthermore, the low heat deflection temperature of PLA makes it fundamentally unsuitable for load-bearing applications in warm environments, a limitation that PETG successfully addresses with its superior thermal stability and higher glass transition threshold.
Audrius Zidonis headshot
Audrius Zidonis PhD
Still have questions about PETG or PLA? Then reach out to one of our representatives. We also offer lots of manufacturing services including CNC machining, laser cutting, and, of course, 3D printing. You can quickly and easily upload your designs to our website and get your free, no-obligation quote today.
