Product Update : 5 New Processes Added to the Xometry Quoting Engine
The process menu of the Xometry Quoting Engine has been expanded with the addition of five new processes : Die Casting, Metal Extrusion, Metal Stamping, Laser Tube Cutting, and Tube Bending.
Die Casting
Die casting is the manufacturing process of choice when producing high volumes of relatively complex metal parts and is widely used due to its versatility, reliability, and accuracy. Die casting eliminates all or most secondary operations needed to make a metal part; however, post-machining is common to meet tighter critical-to-function tolerances.
Die casting works by injecting molten metal into a die cavity, which takes the shape of the part and hardens into place before removal. Depending on the project scope, die casting can be low- or high-pressure, using a ladle or plunger to deposit metal. Die casting can produce highly complex, tight-tolerance parts in a repeatable manner at very high production volumes.
Learn more by visiting our Die Casting Services page.
Metal Extrusion
Metal extrusion is the manufacturing process of choice when producing high volumes of material with a constant cross-section. With the extrusion process, metal material is forced through the shaped opening of a die using high pressure, resulting in an extruded profile. These profiles range from simple shapes like round or rectangular tubes, U- or H-channels, or more complex profiles with multiple internal hollows and external features, such as 80/20 and T-slot framing bar.
Learn more by visiting our Metal Extrusion Services page.
Metal Stamping
Metal stamping is an excellent way to mass-produce various complex parts, from car door panels and gears to small electrical components used in phones and computers.
Learn more by visiting our Metal Stamping Services page.
Laser Tube Cutting
Learn more by visiting our Laser Tube Cutting Services page.
Tube Bending
Learn more by visiting our Tube Bending Services page.
