ResourcesBlogTight Tolerance Parts? Xometry Delivers
picture of Joel Schadegg
picture of Greg Paulsen
 1 min read
Published March 11, 2025
Learn about Xometry's capability to meet tight tolerance requirements for your CNC, sheet metal, and sheet cut parts.
Tight Tolerances? No problem.
  • Need precise CNC, sheet cut, or bent metal parts? Xometry hits tight tolerances.
  • Instant quotes: Specify your toughest requirement, get pricing fast.
  • Expert review: For ultra-tight needs, our team ensures accuracy.
CNC Machining Tolerance Capabilities
Thanks to our platform, getting precisely milled or turned CNC parts is simple. We can automatically quote tolerances as tight as +/- 0.001" for various materials, including some plastics! We regularly machine parts with tolerance bands even narrower than this; however, features other than small and shallow reamed holes will require manual review.
Our CNC machining tolerance capabilities include:
  • Auto-quotable tolerances down to +/- 0.001" for all metal materials
  • Auto-quotable +/- 0.001" tolerances for PEEK, ULTEM, Delrin, Acetal, and PTFE plastics
  • Sub +/- 0.001" tolerances achievable after manual review
  • Default tolerances of +/- 0.005"
Get Our Free CNC Design Guide
Sheet Metal Fabrication Tolerance Capabilities
With our sheet metal fabrication service, you can get high-precision bent sheet parts from tight-fitting brackets, instrument panels, perfectly aligned enclosures and chassis, and more! We can automatically quote sheet metal tolerances down to +/- 0.005", allowing you to quote and order your precision sheet parts without further delay. If your parts require inserts, that's not a problem. You can specify them in our system, and we will install them accordingly without the need to specify tight tolerances on insert features.
Our sheet metal bending tolerance capabilities include:
  • Instant pricing and lead times on tolerances as tight as +/- 0.005"
  • Sub +/- 0.005" tolerances after manual review
  • Insert installation without the need to call for tight tolerances on corresponding features
  • Default bending tolerances of +/- 0.020"
Various metal stamped pieces
Laser and Sheet Cutting Tolerance Capabilities
Xometry's manufacturing network utilizes the latest laser and waterjet cutting machinery, enabling us to cut flat sheet parts with extreme accuracy. Our service makes manufacturing precision covers, plates, washers, shims, and various other parts for automotive, aerospace, medical, and other industries quick and easy. We provide instant pricing and lead times for metal or plastic sheet-cut parts with tolerances as tight as +/-0.005". Like our other offerings, we can support even tighter tolerances after further review.
More about our sheet cutting tolerance capabilities:
  • Auto-quotable tolerances as tight as +/- 0.005" for metals and plastics
  • Sub +/- 0.005" tolerances available with manual review
  • Default tolerances of +/- 0.010"
Various aluminum sheet cut parts made by Xometry.
Looking for Laser and Sheet Cutting Design Tips?
Tight Tolerances Made Simple
Configure Your Part
Click "Edit Configuration" to configure your parts.
Get your Instant Quote, Customize, and Place Order
Specify Tightest Tolerance
Check the box under "Tolerances" and select your part's tightest tolerance requirement.
quote engine
Get Your Quote
Pricing and lead time will update automatically based on your selection.
Need Tight Tolerance Parts?
Joel Schadegg
