ResourcesMachining DesignCNC Machining Cost Calculation: Calculator, Factors, and How to Reduce Cost
Published July 16, 2023
Updated January 7, 2026
Everything you need to budget for and how to keep your expenses down
Machine tool. Image Credit: Shutterstock.com/NDAB Creativity
CNC machining makes for a quick and efficient way of production, especially for precise components (even in large batches). It’s little wonder that it’s a firm favorite with manufacturers everywhere. There are, however, plenty of costs associated with this method, which we’ll break down in this article.
CNC Machining Cost Calculator
Before we go into exactly how each part of the process can contribute to how you spend your budget on CNC machining, here’s our very own cost calculator to help you work out how much your custom parts will ring up, and provide you with an instant quote.
Factors That Determine Machining Cost
The costs of CNC machining projects include more than just the material and the machining. Below you’ll find all the factors that impact the final amount you’ll need to pay.
Material Selection
If you’re looking to break down the costs between different types of materials, you’ll have to compare how easily available (or not) they are to find and how easy or difficult they are to machine. High-performance alloys tend to be spendier than common metals, and harder or less machinable materials that need specialized tooling and longer machining time will also affect the total. Choosing more affordable materials is perhaps the most obvious way to cut costs, but standardizing material options across product lines can simplify your procurement process too. This will reduce waste, and improve machining efficiency.
The table below gives you a rough idea of what typical CNC machining materials cost, the forms they come in, and their common applications.
MaterialApprox. Cost (USD/kg)*FormApplications
Material
$5–$15
Form
Blocks, sheets, rods
Applications
Aerospace, automotive, electronics, consumer goods
Material
Stainless steel
$15–$25
Form
Applications
Medical devices, kitchenware, industrial machinery, marine
Material
Carbon steel
$2–$5
Form
Blocks, rods
Applications
Tools, automotive, heavy machinery
Material
Titanium
$30–$50
Form
Blocks, rods
Applications
Aerospace, medical implants, high-performance automotive parts
Material
Brass
$10–$20
Form
Rods, blocks
Applications
Electrical connectors, decorative items, fittings, musical instruments
Material
Copper
$9–$15
Form
Sheets, blocks, rods
Applications
Electrical components, heat sinks, plumbing fittings
Material
ABS
$2–$4
Form
Sheets, rods
Applications
Prototyping, electronics, automotive
Material
Nylon
$3–$6
Form
Rods, sheets
Applications
Gears, bearings, machine components, consumer goods
Material
Delrin
$4–$8
Form
Rods, sheets
Applications
Precision components, medical devices, mechanical gears
Material
Acrylic
$3–$6
Form
Sheets, blocks
Applications
Displays, signage, optical components
Material
Tool steel
$10–$20
Form
Rods, blocks
Applications
Cutting tools, molds, dies, high-stress industrial applications
Material
Inconel
$60–$80
Form
Rods, blocks
Applications
High-temperature aerospace parts, turbine blades
Material
Magnesium
$10–$20
Form
Blocks, rods
Applications
Lightweight vehicle and aerospace parts
Material
Hardwoods
$2–$10
Form
Blocks, boards
Applications
Furniture, decorative items, prototypes
Material
Composites (G10)
$30–$50
Form
Sheets
Applications
Aerospace, electronics, mechanical parts
*Based on 2025 estimates
Complexity of Design
If your design is complex and has tight tolerances, you can expect to pay a little more. This is because intricacies like these will probably need more advanced machining techniques, specialized tooling, and longer machining times. Although it’s not always possible for some items, if you can simplify your designs and choose more basic products and parts, your costs can go down. If the whole process is a bit confusing, you can reach out to a design engineer to tailor your designs to your specific needs without compromising the functionality and quality of your products. An expert like this can help you get the most out of your money and designs, and even though they will also charge for their services, you’ll likely end up saving a whole lot more in the long run.
Machining Time
A long machining time almost always equals higher costs. This is due to factors like extra electricity and power being used and the time it takes to cut parts or change tools. The effectiveness of production can also determine how long it’s going to take to get your items machined.
Machine Tooling
Under this category, you can expect to pay for the purchase, maintenance, and/or replacement of the cutting tools used by the machine. The lifespan of the cutting tools and the time required for tool changeovers directly affect efficiency. Proper selection of tools suited to the material and machining process and regular maintenance can reduce machining expenses and improve overall productivity.
Volume and Batch Size
Larger production volumes benefit from bulk prices so there’s lower cost per part as fixed setup costs are spread across more units. Smaller batch sizes will often have higher costs per part, so you should consider whether it’s worth increasing your batch size to keep costs low.
Labor Costs
Skilled CNC operators are responsible for programming, setup, and operation, and are needed for effective and accurate machining processes. When these workers are required to spend more of their valuable time, such as on projects with intricate parts, you can expect additional costs. Further down we mention how automation can help lower what you’ll have to pay for workers.
Overhead Costs
Expenses will start even before you get started making products. Facilities, utilities, administrative operations, quality control, and inspection processes… these are all overheads that will need to be factored in. Effective management is the best way to keep track of everything, make sure you’re within budget, that income is more than outgoings, and that you’re not overpaying for anything.
Scrap and Rework
Machining errors or deviations from design specifications can lead to wasted material… which is basically money down the drain. You can keep scrap material and the need for reworking parts down with effective quality control measures, precision machining techniques, and thorough inspections. Again, this has to do with management.
CNC machined part
CNC machined part
How To Reduce CNC Machining Costs
In addition to the tips provided in each of the above cost-influencing factors, here are some of the categories in which you can save some cash.
Supplier Collaboration
Collaborating with CNC machine suppliers is valuable for exploring cost-saving opportunities. Engage with suppliers to negotiate favorable pricing, especially for bulk material purchasing. Manufacturers can optimize supply chain logistics, improve delivery times, and reduce transportation costs by establishing solid supplier relationships. Collaborative efforts can also lead to developing innovative solutions and cost-saving recommendations based on suppliers' expertise and CNC machining industry knowledge.
By implementing these cost-saving strategies, manufacturers can effectively reduce CNC machining expenses and enhance their competitive edge in the market. A comprehensive approach that combines design optimization, material selection, process optimization, automation, and supplier collaboration can result in significant cost savings while maintaining high-quality production.
Design Optimization
Designing parts for manufacturability is crucial for cost reduction in CNC machining. Manufacturers can streamline the machining process and minimize material waste by simplifying the geometry, minimizing tight tolerances, and reducing the number of operations. Collaborating with design engineers to optimize part designs for CNC machining can significantly reduce production time, tooling requirements, and overall costs.
Material Selection and Standardization
Careful material selection and standardization can significantly save costs. Manufacturers can reduce material expenses by choosing cost-effective materials that meet the required specifications. Standardizing material options across product lines can simplify procurement, minimize waste, and enhance machining efficiency. Material availability, price, and compatibility with machining processes should be considered during material selection.
Process Optimization
Compex toolpaths will make more movements and more machining time (in other words, more money), but if you try to simplify these, use work-holding solutions, and strategic tool change methods, the process and setup can be sped up. Lean manufacturing techniques such as 5S, value stream mapping, and continuous improvement initiatives will help identify and eliminate waste — which can also be helped with proactive maintenance and scheduling to maximize machine uptime for consistent output.
Automation and Robotics
Robotics and automation are making their way into every industry, and CNC machining hasn’t been left behind. Here’s why these systems can be more beneficial than using human-powered work:
  • Much less likely to make mistakes
  • Won't get fatigued—even when working for hours on end
  • There aren’t labor laws limiting your use
  • Excellent for repetitive tasks and great at repeating the same design or action
  • Makes consistently high-quality parts with no variations
  • Not as expensive (they might have hefty upfront costs, but more than make up for the initial investment, especially for mass production)
  • Very accurate
  • Very little waste and reworking needs
Offloading these jobs to robots can give skilled operators the chance to focus on other more complex assignments that are a much better use of their time, energy, and expertise (and your money!).
Many factors go into CNC pricing. Short lead times drive cost due to overtime and expedites on material and finishing. Special tooling or processes (EDM) can also play a significant roll in driving cost.
Jason McClure
VP, Manufacturing Operations
For additional information about CNC machining costs, contact an Xometry representative. We also provide a wide range of manufacturing capabilities and other value-added services for all of your prototyping and production needs. Visit our website to snag a free, no-obligation quote.
