ResourcesMaterialsAll About Bronze Metal
Published January 10, 2024
Updated September 26, 2025
Beyond medals, this attractive metal has many uses in the manufacturing world.
Bronze metal. Image Credit: Shutterstock.com/Dmitr1ch
Bronze isn’t all foam and no beer—it’s just as useful as it is pretty. You’ve surely seen it in the form of door handles, medals, and ornaments (you may even have some of these in your home), but those are certainly not all it’s good for. Engine parts, tools, and pumps are made from bronze, too (okay, and some other fun things like ship’s bells, fountains, and propellers). Read on to learn more about it, and how you can use it for your own manufacturing needs.
What is Bronze?
Bronze is a reddish-brown metal alloy in the “red metal” family made up of 88% copper, and 12% tin. It’s malleable (but harder than copper) so it’s easy to manufacture into different products and has low metal-to-metal friction. It also forms a natural protective layer (patina) on its surface that keeps it corrosion-resistant. Depending on what properties are needed, it’s sometimes mixed with other elements like phosphorus, silicone, or zinc. It’s made using the bronze casting process where it’s melted and mixed with whatever other elements needed, poured it into molds, and allowed to cool and harden. Here’s a cool object (if we do say so ourselves) we 3D printed with bronze:
metal binder jet 3D printed part infiltrated with SS420 bronze
A metal binder jet 3D printed part infiltrated with bronze, made by Xometry.
Different Types of Bronze
There are so many different bronze alloy types (around 50, give or take) that if we were to go through all of them, we’d be here all day. We wrote an article about nine of them, and for ease of reference, we’ll list the five most common types used in manufacturing below, with the amounts of the other elements (in addition to copper) they contain.
Bronze TypeComposition (in addition to copper)
Bronze Type
Aluminum bronze
6–12% aluminum
Bronze Type
Nickel aluminum bronze
6–13% aluminum, up to 7% iron, and 7% nickel
Bronze Type
Silicon bronze
Up to 6% silicon
Bronze Type
Phosphor bronze (or tin bronze)
Up to 11% tin and up to 0.35% phosphorus
Bronze Type
Manganese bronze
Up to 3% manganese
Different Types of Bronze Composition
Properties
In the following two sections, we’ll break down both the physical and chemical properties of bronze, helping you understand the metal a little better.
PropertyDescription
Property
Density (g/cc)
Description
5.60 - 9.30
Property
Color
Description
Reddish-brown metallic color
Property
Melting point (°C)
Description
315 - 1180
Property
Boiling Point (°C)
Description
1400
Property
Thermal Conductivity (W/m-K )
Description
1.01 - 208
Physical Properties of Bronze. Table Credit: https://www.matweb.com/search/DataSheet.aspx?MatGUID=66575ff2cd5249c49d76df15b47dbca4&ckck=1
Now, let’s take a look at bronze’s chemical properties:
PropertyDescription
Property
Corrosion resistance
Description
Good
Property
Electrical and thermal conductivity
Description
Good
Property
Oxidation products
Description
copper oxide and copper carbonate (green patina)
Property
Magnetic
Description
No
Property
Malleability
Description
Good
Property
Ductility
Description
High
Chemical Properties of Bronze
Applications
Bronze can be, and has been, used in so many different settings. Here are just a few of them, both from the past and present:
ToolsBronze was being made into tools and weapons from as early as the Bronze Age (only around 5,000 years ago). Our ancestors were obviously onto something because it’s still being used today to make the same things, including hammers, wrenches, chisels, blades, gears, and bearings.
Tools
Architecture
Architects particularly love bronze as it’s a snazzy addition to any building, offering decorative flair, as well as strength and durability. It’s made into door or window frames, cabinet handles, or trims. Bronze used for architectural purposes is often more natural in color, but if it’s used outside (sculptures or ornaments) it’s usually patinized.
Tools
Coins
Back in ancient times, bronze was one of the two main metals for coins, alongside copper. Modern coins, though, have replaced them with metals like copper-plated steel, zinc, and nickel, mainly for pricing reasons.
Tools
Instruments
Cymbals, bells, gongs, and a host of other musical instruments can be made from bronze. They’re cast in a very interesting formulation called “bell metal.” Other types of bronze like phosphor bronze are sometimes used to make acoustic guitar and piano strings, too.
Tools
Bells
Bronze can produce a strong and clear tone, hence it’s used to make bells. Like with musical instruments, bells are made from the same “bell metal” which is basically made from 80% copper and 20% tin—a balance that creates very nice sounds and resonance by absorbing energy.
Tools
Bearings
Bronze, in a formulation called “bearing bronze” which is strong and hard, is great for making things like springs, bearings, and bushings, especially when it comes to car transmissions and small electric motors. These types of bearings are usually shock-, impact-, wear-, and corrosion-resistant, and used in sectors like food processing, injection molding, and automotive equipment.
Tools
Medals
Most of us will have first heard of bronze at an early age thanks to the “bronze medal” won in sporting events and other competitions. Before the 1904 Summer Olympics in St. Louis, MO, silver medals were given to winners, and bronze was awarded to the runners-up. Then gold entered the scene and our beloved bronze got relegated to third place.
Bronze Applications
Pros and Cons
Here’s a side-by-side look at what bronze is good and not so good at.
AdvantagesDisadvantages
Advantages
It’s much harder than pure copper or iron
Disadvantages
Its hardness might make it more difficult to work with
Advantages
It has better corrosion resistance, heat and electrical conductivity, and fatigue-resistance than most steels
Disadvantages
It tends to oxidize more easily than copper does
Advantages
It’s easier to cast than copper because it’s more fusible
Disadvantages
It’s often more expensive than steel, brass, or copper
Advantages
It has low metal-to-metal friction
Disadvantages
Its kryptonite is ferric compounds, ammonia, and cyanides—sulfur and chlorine can actually cause it to deteriorate in humid environments
Advantages
It’s both versatile and durable
Disadvantages
As odd as it sounds, bronze can get sick. Bronze Disease (yes, this is a real thing) makes small, rough, pale green spots suddenly appear on its surface when oxygen and chloride react in water. Left unchecked, it could be totally destroyed.
Advantages
It has a good surface finish
Bronze Pros and Cons
Bronze vs. Brass
Xometry customers often ask us about the difference between these two metals when they need a nice-looking metal for their manufacturing needs. It mainly comes down to their composition and properties. Both are copper alloys and corrosion resistant, but bronze can make itself a protective patina, whereas brass will tarnish over time. Brass is made of copper, zinc, and other elements that contribute to its color, which can be bright gold, copper, or silver. It’s more malleable than bronze, which means you don’t have to worry about it breaking when hammered or rolled (within reason, of course).
Xometry provides a wide range of manufacturing capabilities, including 3D printing, laser cutting, CNC machining, and much more. If you want to learn more about bronze, brass, or any other type of metal, or request a free no-obligation quote, reach out to a Xometry representative today.
