ResourcesMaterialsUnderstanding the Differences Between Polycarbonate and Polyethylene
Rebecca Piccoli headshot
Published January 20, 2023
Updated November 14, 2024
A closer look at two popular thermoplastics and how they’re used
Colorful polycarbonate sheets. Image Credit: Shutterstock.com/Cat Us
Two materials that are often said in the same breath are polycarbonate and polyethylene. They’re both plastics but they bring very different properties and uses to the table for manufacturers. This article is a written Venn diagram of sorts that will compare the two plastics to help you best decide which will be the most useful in the products you have in mind.
What is Polycarbonate?
Plastics might literally be known for their plasticity and flexibility, but polycarbonate (PC) is one such material that’s renowned for its impact strength, toughness, and durability. This thermoplastic is made up of polymers surrounding carbonate groups in their chemical structure. When compared to other similar manufacturing materials, PC is relatively inexpensive, but prices will vary depending on its weight and any extra properties. The image below shows an example of a PC part made by Xometry.
A molded polycarbonate gear
What is Polyethylene?
Polyethylene (PE) ranks high up there when it comes to other extremely popular thermoplastics in the world of manufacturing. It’s a homopolymer with chains of ethene molecules and is a useful material for everything from plastic bags to medical implants. The most common formats of this plastic are low-density (LDPE) and high-density (HDPE) polyethylene. LDPE is more elastic as it has a lower density and its chains are made up of side branches within its chemical structure. As shown in the below diagram, HDPE has more closely packed chains, which makes it denser.
Polyethylene molecular structure
Polycarbonate vs. Polyethylene
This table shows the differences in physical properties and applications between PC and both high- and low-density PE.
PropertyPolycarbonateLDPEHDPE
Property
Optical transmission
Polycarbonate
Very high (better than glass)
LDPE
Moderate, which can be improved through biaxial orientation
HDPE
Poor to none
Property
Density
Polycarbonate
1.2 g/cm^3
LDPE
0.915–0.96 g/cm^3
HDPE
0.933–1.27 g/cm^3
Property
Hardness (Shore D)
Polycarbonate
90–95
LDPE
42–56
HDPE
55–69
Property
Tensile strength (ultimate)
Polycarbonate
28–75 MPa
LDPE
8.96–54 MPa
HDPE
15.2–45 MPa
Property
Yield strength
Polycarbonate
39–70 MPa
LDPE
7.6–14 MPa
HDPE
2.69–200 MPa
Property
Elongation at break
Polycarbonate
10–138%
LDPE
226–650%
HDPE
3–1900%
Property
Modulus of elasticity
Polycarbonate
1.79–3.24 GPa
LDPE
0.152–0.29 GPa
HDPE
0.483–1.45 GPa
Property
Flexural yield strength
Polycarbonate
36–103 MPa
LDPE
14–21 MPa
HDPE
16.5–91 MPa
Property
Flexural modulus
Polycarbonate
0.971–3.1 GPa
LDPE
0.07–0.276 GPa
HDPE
0.5–4.83 GPa
Property
Dielectric constant
Polycarbonate
2.85–3.17
LDPE
2.27–2.29
HDPE
2.0–2.6
Property
Melting point
Polycarbonate
288–316 °C
LDPE
102–113 °C
HDPE
120–130 °C
Property
Max service temperature
Polycarbonate
115–135 °C
LDPE
80–100 °C
HDPE
80–120 °C
Property
Applications
Polycarbonate
Medical cameras, lenses, face shields, safety goggles, DVDs, cupboards, kitchen paneling, weather shields, bags, suitcases, windows, greenhouse roofing
LDPE
Plastic bottles, plastic bags, trays, computer parts, tubes, containers, caps, fuel cans and drums, trash bins, cables, clips
HDPE
Ropes, fishing, sports nets, industrial and decorative fabrics, recycling bins, food and beverage packaging, pipes, milk jugs, toys
Property
Cost
Polycarbonate
Around $2.80 per kg or $1.60 per kg for recycled
LDPE
About $0.90–$1.10 per kg for granules
HDPE
About $8.50 per kg, or around $2.50 for recycled material
Property
Recyclability
Polycarbonate
Highly recyclable through sorting, shredding, and remelting
LDPE
Highly recyclable except for film products and often more expensive to recycle than to use virgin material
HDPE
Polycarbonate vs. Polyethylene Physical Properties
Alternative Materials
There are a few materials that work in similar ways to PC and PE, and are good considerations depending on what application you’re sourcing for:
  • Acrylic: While it’s not as strong as PC or PE, acrylic is perfectly workable for windows and other applications. One example is Trivex.
  • Polystyrene: More transparent versions of PS can be a good swap for products like light guides, especially since PS is weaker and more easily broken than PC.
  • Acrylonitrile butadiene styrene: ABS is perfect if you want a plastic that doesn’t need extreme flexural resilience or ultimate strength. It’s a popular choice for things like 3D printing and injection molding.
We’re extremely familiar with all the ways in which you can process and manufacture polycarbonate and polyethylene. Through our website, you can get free quotes for related services, like plastic 3D printing, injection molding, and compression molding.
  1. Trivex™ is a registered trademark of PPG Industries Ohio, Inc.
