Laser Power: Definition, How It Works, Importance, and How to Determine
Published July 21, 2023Updated January 24, 2025
Laser power. Image Credit: Shutterstock.com/Pixel B
Laser power is defined as the energy delivered by a laser beam per unit of time and per unit of area. Many factors determine the application and utility of laser emission, including monochromaticity, central frequency, coherence, collimation, beam quality, minimum spot size, beam power, and irradiance. Laser power can be measured using various methods. The most powerful source does not necessarily produce the most significant effect. The product documentation typically specifies source power as a standard characteristic, although photometric tools are also available for direct measurement. In laser cutting applications, the power and its ability to generate a high-intensity spot are two critical parameters. Spot size and the energy intensity at that spot determine the beam’s effectiveness in initiating and performing cutting operations.
This article will further discuss laser power, its definition, how it works, its importance, and the recommended settings.
What Is Laser Power?
Laser power defines the energy a laser beam delivers per unit of time and area. It is a crucial parameter in laser systems and plays a significant role in determining a cutting or engraving machine's cutting, engraving, or marking capabilities. The absolute laser power is typically measured in watts (W, kW), representing the rate of energy transfer to the cut point. The power output of lasers varies widely, ranging from a few milliwatts for low-power devices in consumer electronics or laser pointers to tens of kilowatts for industrial laser systems used in cutting or welding.
In laser cutting or material processing applications, the laser power directly affects the cutting speed and the depth or intensity of the laser's interaction with the material. Higher laser power enables faster cutting of thicker sections or harder-to-cut materials. The ability to process material rapidly also depends on the spot size and beam quality, as these increase the power per unit area, concentrating the laser power onto the smallest possible spot size to increase the intensity of energy at the cut by increasing the specific energy.
The appropriate laser power for a specific application depends on factors such as the material type, thickness, desired cut quality, and the capabilities of the laser cutting machine. Plastics or organic materials generally have higher absorption rates in the more common laser cutter frequency ranges, requiring lower laser power for effective cutting.
Laser power can often be adjusted or modulated to suit specific application requirements. Laser systems typically control the power level or pulse frequency/duration, allowing operators to optimize the power output based on the desired cutting speed, precision, material type/thickness, and required cut quality.
How Does Laser Power Work?
The laser produces a stream of coherent and collimated photons directed toward the workpiece or application point via light pipes or mirrors. Just before the beam hits the surface to be cut/welded/engraved, it passes through a lens arrangement that focuses the laser to a minimum spot size to deliver a narrow spot of maximum intensity at the required cut point. The energy that hits the surface causes extreme excitation of atomic bonds, which manifests as heat at the laser contact point. When that heat is sufficient, it either liquefies the material at the laser spot, vaporizes it, or combines the two.
When the beam delivered is of high quality, the energy distribution is symmetrical around the center line of the beam. It offers a Gaussian distribution, making the focused dot the maximum possible intensity at its center. A lower-quality beam may have a less regular/symmetrical distribution of energy. The energy concentration may be lower at the center of the spot, lowering the specific energy at the spot center and reducing the available cutting power.
Laser cutting acrylic at Xometry
What Is the Importance of Laser Power?
Laser power, assessed by various overlapping methods, plays the most crucial role in laser-based applications. Laser power significantly affects process speed and productivity in laser cutting, welding, or engraving applications. Higher power capacity allows faster processing rate and higher productivity. It also increases the spectrum of processing capability, allowing throughput of thicker or more resilient materials that require more energy. Higher available laser power provides flexibility in delivering a wider range of processing—necessary for thicker material, hard/resilient material, and faster processing. Elevated laser power allows for sharper cuts, finer engraving, and greater intricacy.
The upper limit of laser power impacts efficiency and productivity, enabling reduced processing time. This saves cost by reducing machine time and improving throughput/capacity. Significantly, in cost terms, adjusting laser power (up or down) to suit specific material requirements can minimize material waste and improve overall process efficiency.
How Important Is Laser Power in Laser Cutting?
Power is necessary but not the only important factor in laser cutting. In reality, relatively low power is required for most tasks. For example, cutting thin organic materials and polymers places very low absolute power demands on a cutting machine. Power is often the deciding factor in completing the task at the more challenging end of processing, such as handling metals, thicker materials, reflective surfaces, and harder materials. For more information, see our guide on What Does a Laser Cutter Do?
How To Determine Laser Power?
Some methods to measure laser power are listed below:
  1. Laser Power Meter: A sensor or detector absorbs the net laser energy and converts it into an electrical signal measured by the meter. These can be thermal sensors, photodiodes, or pyroelectric sensors.
  2. Integrating Sphere: A spherical enclosure with a highly reflective interior surface. It is used to measure the total power emitted by a laser. The laser beam is directed into the sphere, where it is scattered and evenly distributed. The power is then measured using a sensor or detector placed within the sphere—out of the direct laser path. Integrating spheres is more applicable to high-power lasers and the assessment of pulsed beams.
  3. Beam profiling: Informs about the spatial distribution of the beam and assesses beam quality and uniformity. Evaluating the divergence from Gaussian distribution informs about effective power. A CCD (charge-coupled device) camera or a scanning slit device can help visualize and analyze this characteristic.
  4. Measurement: The absolute power can be indirectly estimated by measuring the beam diameter and the energy density. Power density is derived by dividing the measured net energy by the pulse duration or the exposure time. This method is most relevant to pulsed lasers.
"Regular maintenance and calibration of a laser cutter controls the quality of manufacturing. A calibrated laser ensures there are precise cuts and quality edges, and minimizes scrap. If a laser is not maintained on a regular schedule, the laser cutting head will become out of alignment, wasting expensive material and precious time. A regularly scheduled Preventative Maintenance Plan is important to maintaining quality and controlling costs."
Jacob ThompsonSenior Solutions Engineer
What Is the Recommended Laser Power for Laser Cutting?
Recommendations for laser power settings are wide-ranging, as they are compatible with various equipment types, materials, thicknesses, and quality implications. For example, varied materials have characteristic absorption spectra for laser energy, affecting equipment selection (laser frequency) and power needs. Some metals that standard lasers emit are highly reflective in the IR spectrum. The precise properties of the material being cut profoundly influence the power required.
Thicker materials require higher laser powers to achieve practical productivity and minimize the heat-affected zone (HAZ). Thicker materials cut with too little power enable excessive heat buildup—rather than fast vaporization or melt-blow removal. Thinner materials benefit from lower laser powers to minimize HAZ and char damage.
Determining the optimal power setting for a task involves experimentation and adjustment through sample testing, results assessment, and power adjustment.
How Thick Can a 6,000-Watt Laser Cut?
The thickness of aluminum that a 6-kW laser can cut will vary according to the laser type/frequency, beam quality, optics quality, and the type and grade of aluminum. While a 6,000-watt laser can cut aluminum of considerable thickness, there are absolute limits to the thickness for good quality and rapid processing. Generally, a 6,000-watt laser can cut aluminum up to approximately 25–30 mm (1–1.2 inches) for low-alloy aluminum and 20–25 mm (0.8–1 inch) for high-grade plate aluminum.
What Is the Recommended Laser Power for Laser Engraving?
There is no simple instructed value for power level in laser engraving aluminum. It depends on factors like the desired engraving depth, surface finish, and the aluminum's type/grade/annealing.
For example, the types and grades of aluminum have different absorption properties for laser energy. Generally, aluminum is highly reflective, so high laser power is required for effective engraving. The desired depth of the engraving also plays a central role in determining the laser power. Deeper engravings typically require higher laser powers. However, less deep engraving often benefits from lower power and increased passes.
For many aluminum engraving applications, a power of 10 to 50 W suffices for good results, and few applications benefit from laser powers of more than 100 W. For more information, see our guide on the Laser Engraving Process.
Are 100 Watts of Laser Power Too Much for Laser Engraving?
Yes, a 100 W laser at fixed power may be too powerful for good-quality engraving. If power can be reduced by absolute settings or pulse duration, then a 100 W laser will provide a significant capability that can be precisely adjusted to the task. It is a good idea to evaluate performance in a task’s initial setup, dialing back power settings and speeds and then increasing them cautiously.
What Is the Recommended Laser Power for Laser Welding?
The recommended laser power for laser welding highly depends on the type and thickness of the materials being welded, the joint configuration, the weld quality required, and the specific capabilities/quality of the welding system being used. For example, materials have varied absorption properties for the beam energy, so the power required to initiate welding will depend on the material. Also, the section thickness will profoundly affect the ability to generate sufficient heat. Thicker material at the joint line will require higher power to achieve proper penetration and weld strength. As with all laser-based processes, a careful evaluation of equipment capabilities, operational parameters, and quality of results is required, using sample materials before a process can be confidently executed. For more information, see our guide on How Laser Welding Works.
Is 4-kW Laser Power Good for Laser Welding?
Yes, a 4-kW laser will suffice for welding aluminum, depending on the joint geometry, material thicknesses, and speed of operation required. Aluminum has relatively high reflectivity and thermal conductivity compared to many materials. This tends to impose higher power requirements for effective processing. Laser type will also affect welding productivity or capability, given the better energy absorption at some laser frequencies. For example, CO2 laser energy is significantly reflected by aluminum, whereas Nd:YAG emission frequencies are almost entirely absorbed.
Which Is More Important, Laser Power or Speed?
Laser power and speed are critical factors in achieving good laser-cutting aluminum productivity. In reality, the power defines the processing speed to a great extent. Laser power is essential in processing aluminum effectively. Sufficient power is necessary for effective melt/vaporization to deliver a clean and precise cut. Higher power provides for faster processing, especially for thicker sections. Multiple passes can compensate at a cost to throughput and quality.
Striking a balance between power and processing speed is the route to optimal results. Consider the thickness and type of aluminum, desired cutting quality, and the parameter capabilities of the laser processing equipment. The goal is to maximize cutting speed without sacrificing the quality and accuracy of the cut.
This article presented laser power, explained it, and discussed its importance and how it works. To learn more about laser power, contact an Xometry representative.
