Xometry Rhodium Plating Services
Get Quotes in Two Hours and Parts Finished in as Fast as 2 Days. MIL-R-46085, ASTM B634, and AMS 2413 Available.
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Rhodium Plating Overview
Rhodium is a precious metal in the platinum group that does not oxidize, making it ideal for coating parts for electronic components, PCB’s, semiconductor components and much more. It is resistant to corrosion, oxidation, tarnishing, and scratches, making it an idea protective coating. Its boiling point is 3727°C and its melting point is 1966°C. Major advantages of rhodium include its resistance to heat, ability to prevent mechanical wear, electrical conductivity, and ability to reduce friction. Rhodium is whiter in color than palladium and platinum. It is frequently used to plate white gold to improve its appearance and to plate sterling silver to increase its resistance to tarnishing. Rhodium helps to protect sliding electrical contacts against galling and sliding contact wear. Specifications: MIL-R-46085, ASTM B634, AMS 2413, STM B634 – 88 (Re-approved 1999) Standard Specification for Electro-deposited Coatings of Rhodium for Engineering Use and MIL-R-46085 Rhodium Plating, Electro-deposited are relevant specifications for covering the requirements of the electrodeposition of rhodium over metallic surfaces.
  • Atomic symbol: Rh
  • Atomic weight: 102.9055
  • Atomic number: 45
  • Thermal conductivity: 150 J/(m-sec-K)
  • Electrical conductivity: 221.729 1/mohm-cm
  • Electro-negativity: 2.28
Quality
Competitive Pricing
Access a deep network of world-class rhodium platers, helping you find the suppliers you need at competitive prices.
Fast Quoting
Massive Network Capacity
Streamlined Communication
Anodizing
Metal Plating
  • Copper Plating
  • Electroless Nickel
  • Electrolytic Nickel
  • Nickel Plating
  • Nickel Sulfamate
  • Nickel Watts
  • Tin
  • Zinc
Precious Metal Plating
Adhesives and Coatings
  • Black Oxide
  • Dry Film Lubricants
  • Powder Coat
  • Wet Paint
Conversion and Pretreatments
  • Chem Film
  • Chromate Conversion Coating
  • Heat Treat
  • Passivation
  • Pickle and Oil
Surface Treatments
  • Bead Blasting
  • Electropolishing
  • Etching
Part Marking
  • Ink Stamping
  • Laser Marking
  • Silk Screening
Heat Treatments
  • Annealing
  • Carburizing
  • Cryogenic Treatment
  • Flame Hardening
  • Hydrogen Embrittlement Relief
  • Induction Hardening
  • Nitriding
  • Stress Relieving
Certifications
  • AS 9100D
  • ISO 13485
  • ISO 9001:2015
  • ITAR
  • NADCAP
  • RoHS
Finishing Services at Xometry
number 1
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
number 2
Create and Submit Your Request
Send a breakdown of your project's requirements to the finisher of your choice complete with details on your finishing needs and any necessary files.
number 3
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
finished parts
Experience the Fastest Way to Get Multiple Finishing Quotes
