How to Read Aluminum Alloys and Tempers
Written byGreg Paulsen
Published November 13, 2020Updated August 26, 2026
Properties of aluminum materials can vary significantly based on alloy composition and how that alloy is tempered after its creation. Read this article to learn more about aluminum alloys within the standard naming system.
Aluminum is a metal that combines robust mechanical properties with low weight. It is significantly lighter than other metal counterparts, such as steels. Many applications are weight-sensitive, so the use of aluminum in vehicular, aircraft, spaceflight, and equipment designs is very common. Aluminum materials are most often formed from casts or extrusions and are go-to materials for CNC machining and sheet metal parts.
Not all aluminum stock is the same. Properties of aluminum materials can vary significantly based on alloy composition and how that alloy is tempered after its creation. Aluminum alloy is defined using standard naming, this article helps better understand the aluminum alloy designation system.
An additional suffix after tempers can signify the wrought product type for even more specific material specifications. The example table below shows the classifications for aluminum 7075-T7351.
Classifications for Aluminum 7075-T7351
Letter Indicator in 7075-T7351
7XXX-series
T7
351
A breakdown of what each character in aluminum 7075-T7351 means for that specific alloy.
Understanding Aluminum Series
Aluminum is typically alloyed with other elements to produce different strengths. These alloys are defined by strength in their series, with labels ranging from 1xxx- to 7xxx-series depending on the alloying agents used. The chart below shows different alloy series and what makes them unique.
Types of Aluminum Alloys
Alloy SeriesAlloying Agent(s)DescriptionExamples
Alloy Series
1xxx
Alloying Agent(s)
99%+ Pure Aluminum
Description
Is soft, ductile, and easily welds. Is not heat-treatable.
Examples
Aluminum 1100
Alloy Series
2xxx
Alloying Agent(s)
Copper
Description
Has high strength and durability and requires corrosion protection.
Examples
Aluminum 2024
Alloy Series
3xxx
Alloying Agent(s)
Manganese
Description
Is highly ductile, great for bending, and best suited for forming.
Examples
Aluminum 3003
Alloy Series
4xxx
Alloying Agent(s)
Silicon
Description
Has a lower melting point and is used as a welding wire.
Examples
Aluminum 4032
Alloy Series
5xxx
Alloying Agent(s)
Magnesium
Description
Has high strength and malleability, is great for bending, and is corrosion-resistant.
Examples
Aluminum 5052
Alloy Series
6xxx
Alloying Agent(s)
Magnesium + Silicon
Description
Has high strength and formability. Is weldable, heat-treatable, and corrosion resistant. Has wide range of use across industries.
Examples
Aluminum 6061, Aluminum 6063
Alloy Series
7xxx
Alloying Agent(s)
Zinc
Description
Has very high tensile strength and stiffness as well as high usage in aerospace designs. Is not suitable for bending.
Examples
Aluminum 7050,
Aluminum 7075
Wrought aluminum alloy lookup table. 2xxx, 5xxx, 6xxx, and 7xxx-series are the most typical alloys used in aerospace and defense.
The secondary numbers before the temper are specific alloy compositions per aluminum series. 6XXX-series aluminum, like 6061, is very popular because it does not work-harden quickly, allowing greater ease of raw material manufacturing through the extrusion of profiles. This reduces the costs of raw stock material fabrication. The material is also easily CNC milled for custom manufacturing. However, 6061 may be too brittle for rolling or forming. This is why 5XXX-series aluminum, like 5052, is most common in sheet metal fabrication or stamping applications.
An alternative to wrought billets is cast aluminum. This material provides a near-net-shape of the product. MIC-6 is a cast 5083 aluminum that is used for tooling plates and test fixtures.
Understanding Aluminum Tempers
To classify aluminum types beyond the net shape and strength of the alloy, temper is used in the naming series. Tempers add additional mechanical properties through rapid cooling (quenching), cold working, or precipitation heat treatment combinations.
Aluminum and alloys from 1XXX-, 3XXX-, 4XXX-, 5XXX-series can not be heat treated but can be strain hardened. This is signified with a suffix of -H##. Strain hardening strengthens a material through cold working. For example, Aluminum 5052-H32. 2XXX-, 6XXX-, and 7XXX-series aluminum can be precipitation hardened, or heat-treated, signified by a -T#, such as 6061-T6. The following reference chart depicts different aluminum tempers.
Reference Table for Different Aluminum Tempers
Extrusion TemperDescription
Extrusion Temper
F
Description
Extruded, air-cooled with no special controls
Extrusion Temper
O
Description
Fully annealed to the lowest strength temper
Extrusion Temper
H1
Description
Strain-hardened
Extrusion Temper
H2
Description
Strain-hardened and partially annealed
Extrusion Temper
H3
Description
Strain-hardened and stabilized
Extrusion Temper
H4
Description
Strain-hardened and lacquered or painted
Extrusion Temper
W
Description
Solution heat-treated
Extrusion Temper
T1
Description
Cooled from an elevated temperature and naturally aged
Extrusion Temper
T2
Description
Cooled from an elevated temperature, cold-worked, and naturally aged
Extrusion Temper
T3
Description
Solution heat-treated, cold-worked, and naturally aged
Extrusion Temper
T4
Description
Solution heat-treated and naturally aged
Extrusion Temper
T5
Description
Cooled from an elevated temperature and artificially aged
Extrusion Temper
T6
Description
Solution heat-treated and artificially aged
Extrusion Temper
T7
Description
Solution heat-treated and stabilized
Extrusion Temper
T8
Description
Solution heat-treated, cold-worked, and artificially aged
Extrusion Temper
T9
Description
Solution heat-treated, artificially aged, and cold-worked
Extrusion Temper
T10
Description
Cooled from elevated temperature, cold-worked, and artificially aged
Extrusion temper lookup chart. Tempers may have multiple digits after a letter to indicate sub-classifications in each temper, material age condition, and final state.
Looking Beyond Aluminum Alloys and Tempers
Beyond tempers, there may be additional suffix classifications that are specific to that series/temper combination. The Metallic Materials Properties Development and Standardization Handbook, MMPDS-14, is a powerful reference for more complete definitions and standards of metals used in manufacturing.
This excerpt was inspired by Xometry’s ebook: Custom Manufacturing for Aerospace and Defense. You can get an instant quote on custom CNC or sheet metal projects here.
picture of Greg Paulsen
