Polyphthalamide (PPA): Uses, Features, and Process
Published May 21, 2022Updated July 18, 2025
Learn about the material's properties, uses, advantages, limitations, and toxicity.
thermoplastic. Image Credit: MarinaGrigorivna/Shutterstock.com
Polyphthalamide, or PPA, is a semi-aromatic engineering thermoplastic. It is a subset of thermoplastic synthetic resins in the polyamide family.
PPA has different melting points depending on the polymer. For example, PA6T homopolymer melts at 371 degrees Celsius. The melting point must be lowered to make functional polymers, which can be achieved using a longer diamine or copolymerizing 6I.
Three copolymers of PPA have found commercial success due to their lower melting points: PA 6T/66, PA 6T/"DT," and PA6T/6I.
This article explains what PPA is, how it's made, the characteristics, uses, and the advantages and disadvantages of using it in plastic injection molding.
What Is Polyphthalamide (PPA)?
Polyphthalamide is a high-performance resin and member of the nylon family with exceptional thermal, mechanical, and physical properties. It is hygroscopic, opaque, semicrystalline, and can be used in plastic injection molding. Most PPA grades are filled with glass or minerals to enhance stiffness for high-temperature applications. As a result, PPA is often used in applications in place of metal or higher-priced thermoplastic.
How Is Polyphthalamide (PPA) Made?
Polyphthalamide is made of terephthalic acid or isophthalic acid, or a combination of the two, and at least one aliphatic diamine like hexamethylene diamine. The aromatic acid portion encompasses at least 55 molar percent of the repeat units in the polymer chain, making these resins only partially aromatic. The aromatic portion of the polymer backbone raises the melting point, rigidity, heat stability, and chemical resistance while lowering the moisture absorption. However, the enhanced properties come at a price. Phthalimides are much more expensive than typical aliphatic amides and are more difficult to process due to their high melting point.
What Are the Characteristics of Polyphthalamide (PPA)?
The characteristics of polyphthalamide are improved chemical resistance, warpage, higher strength & stiffness at elevated temperatures, creep & fatigue resistance, sensitivity to moisture absorption, and dimensional stability.
The glass transition temperature of PPA rises as the amount of terephthalic increases. If more than 55% of the acidic part of a PPA is made out of isophthalic, then the copolymer is amorphous. Crystallinity helps with chemical resistance and mechanical properties above the glass transition temperature but below the melting point. Amorphous PPA polymers are suitable for warpage and transparency.
Like aliphatic nylons, PPAs can be, and usually are, modified with reinforcing agents such as glass fibers, tougheners, or stabilizers. Formulations with specific properties have been developed. For example, resins can bond directly to elastomers to give plastic-rubber composites and, with approval, can be applicable for direct contact with drinking water and food.
Adding aliphatic polyamides to PPAs creates a PPA/PA blend and lowers the melting point and glass transition temperature, making the blends easier to process when compared to higher melting/softening PPAs.
While there have been extensive investigations into PA/polyolefin blends, little has been published about the properties of PPA/ polyolefin blends. The lack of research may be due to the relatively high processing temperatures needed for PPA-based resins judged against the temperature stability of polyolefins. PPA/PA/polyolefin blends have a good balance of flexibility, strength, stiffness, impact, and thermal performance, indicating that these materials should have commercial utility.
What Are the Uses of Polyphthalamide (PPA)?
Polyphthalamide has many uses. It is used for electronics and electrical, automotive, cables & wires, and many other applications. PPA is a semicrystalline or aromatic polyamide that is generally produced from the combination of isophthalic and terephthalic acids.
Polyphthalamide is used chiefly as an alternative for several metal components in the industries such as automotive and others. PPA can be used for fuel & coolant lines, motor bobbin parts, pump wear rings, fuel line connectors, fuel cut-off valves, water heater manifolds, fuel modules, thermostat housings, coolant pumps, air coolers, and LED headlights.
PPA enables the creation of automobile components with better mechanical strength and decreased overall vehicle weight. As a result, the use of PPA helps to lower fuel consumption. In addition, the high transition and high deflection temperature properties of PPA are expected to increase its adoption in making automotive body parts, boosting the global polyphthalamide market growth. Furthermore, strict government rules and regulations designed to reduce automotive fuel emissions have led many service providers to take measures towards raising the fueling economy of vehicles.
PPA is also used for multiple electronic applications, as the high melting point of PPA allows SMD parts molded from PPA to be assembled using a lead-free soldering process. PPAs are also utilized for USB-C connectors, cable & wire protection, and LED mounts. Other uses for PPA-based resins include gas pipes and supply lines for the oil industry.
Medical applications of PPA include tubing for catheters, toothbrush bristles, and personal care items. PPAs are also used in sports equipment, bushings, valve bodies for showers, and bearing pads in aircraft engines.
What Are the Advantages of Polyphthalamide (PPA) in Plastic Injection Molding?
The advantages of PPA in plastic injection molding are as follows:
  • Very high stiffness and strength
  • Good heat, chemical, and fatigue resistance
  • Can resist infrared soldering environments
  • Low water absorption and relatively low moisture
  • Very low creep tendency
  • Good dimensional stability
To learn more, see our guide on the Uses of Polyphthalamide (PPA).
What Are the Disadvantages of Polyphthalamide (PPA) in Plastic Injection Molding?
The disadvantages of PPA in plastic injection molding are as follows:
  • The material is not inherently flame retardant
  • It requires good drying equipment
  • PPA has high processing temperatures (up to 350 degrees C)
  • It is harmed by powerful oxidants, mineral acids, acetic acid, and formic acid
Frequently Asked Questions About Polyphthalamide (PPA)
This article summarized the characteristics, uses, advantages, limitations, and toxicity of Polyphthalamide (PPA).
About Xometry
Xometry offers injection molding services and 3D printing using a variety of materials. Contact us for a free, no-obligation quote for your product manufacturing needs.
